Solved Linked Images are "invisible" but there
14 years 1 month ago - 14 years 1 month ago #135266 by whitex
Hey guys,
first I want to excuse my bad english, but I think you will understand me :)
Website Url: whitex-modd.de/index.php/community
Login:
User: testuser
Code: Kunena
If you link an external image, it only show it "invisible" - the image is there and you can click on area, than the slider will open. But why the image is not showed, i searched a lot, but don't know how to fix that..
As example here, the last post: whitex-modd.de/index.php/community/23-re...iet-dark-rock-2#4426
Hope you can help me, thanks! :)
Alex
Last edit: 14 years 1 month ago by whitex.
14 years 1 month ago - 14 years 1 month ago #135272 by TKtemp
[strike]
navigate in Kunena Backend -> Forum Configuration -> Uploads tab
What value you entered for this option "Maximum Image Height"?
I assume that it is 0px.[/strike]
Forget what I wrote above. You have some script which add min-height:0px; value to your images.
You should be able to solve issue by adding this few lines to your JOOMLA template css file
#Kunena div.kmsgbody div.kmsgtext img { max-height: 800px !important; }
Hope this helps
Last edit: 14 years 1 month ago by TKtemp.
The following user(s) said Thank You: whitex
14 years 1 month ago #135284 by whitex
Thank you a lot! The Problem is solved, nice man! :)
