Solved Private Messaging Icon Not Visible
14 years 1 month ago #135247 by freedomcoach
When looking at a person's post on my Forum the familiar Private Messaging Icon under their photo is not visible. Not sure why.
My uddeIM is fully installed and operational and I'm able to click on the Private messaging link in the upper right corner of forum page but for some reason that small icon has disappeared. There may be one setting in Admin that governs this icon. All help appreciated.
14 years 1 month ago #135286 by xillibit
can-you put here please the kunena report configuration settings ?
14 years 1 month ago #135296 by freedomcoach
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 160M | Max file upload: 40M
Joomla default template details : btc2012 | author: Illiana Technology | version: 1.0 | creationdate: 2012-03-29
Third-party components: CommunityBuilder 1.8.1 | UddeIM 2.8
Plugins: None
14 years 1 month ago #135298 by TKtemp
you can try this:
Navigate to Joomla Administration -> Kunena Forum -> Kunena Plugins -> EDIT - Kunena - UddeIM integration plugin then for "Ordering" parameter select "Order first" and Save
Hope this helps
The following user(s) said Thank You: freedomcoach
14 years 1 month ago #135311 by sozzled
Freedomcoach: Yes. We can see, from the integration plugin settings in the report that, in this case, the site is trying to use CB's PMS which probably isn't installed and, therefore, no PM glyph. There are also a few other conflicting setting in those integration plugins, too. Better if these were fixed so that you only use that you need.
Thanks, TKtemp. I agree with your recommendation.
14 years 1 month ago - 14 years 1 month ago #135330 by freedomcoach
This did the trick! Thank you! I also unpublished the CB Private Message Plugin.
Sincerely,
Howard
Last edit: 14 years 1 month ago by freedomcoach.
Time to create page: 0.154 seconds
