Solved How to unsubscribe users from topic?
- romagromov
- Senior Member
User subsribed on 300 topics and then his email was deleted.
So, I as admin every day get errror messages about
invalid mailbox
Here one from this messages:
***********@mail.ru
Message was not accepted -- invalid mailbox. Local mailbox **********@mail.ru is unavailable:
user not found
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
*************@mail.ru
Message was not accepted -- invalid mailbox. Local mailbox *********@mail.ru is unavailable:
user not found
This is a copy of the message, including all the headers.
Return-path: <admin@**********.com>
Authentication-Results: mxs.mail.ru; spf=softfail (mx162.mail.ru: transitioning domain of vsehristiane.com does not designate ************* as permitted sender) smtp.mailfrom=admin@*************com smtp.helo=server0.livesmi.ru; dkim=none
Received-SPF: softfail (mx162.mail.ru: transitioning domain of **********.com does not designate **************** as permitted sender) client-ip=***********; envelope-from=admin@**************.com; helo=server0.************.ru;
Received: from [************] (port=35069 helo=server0.*********.ru)
by mx162.mail.ru with esmtp (envelope-from <admin@***********.com>)
id 1TNILw-00081Q-R7
for ***********@mail.ru; Sun, 14 Oct 2012 11:11:13 +0400
X-Mru-BL: 0:0:0
X-Mru-PTR: server0.**************.ru
X-Mru-NR: 1
X-Mru-OF: Linux (ethernet/modem)
X-Mru-RC: unknown
Received: by server0.**********.ru (Postfix, from userid 509)
id C10A65833C6; Sun, 14 Oct 2012 11:11:09 +0400 (MSD)
To: *************@mail.ru
So, I need only one thing - manually unscribe this user from all topics...
Download Free Software for Windows absolutly free.
You can do several things:romagromov wrote: So, I need only one thing - manually unscribe this user from all topics...
(1) Ask the user to give you a working mailbox;
(2) Disable the way your site behaves so that you (as the administrator) receive failed email messages in your account;
(3) Login to the user's account yourself, and remove their subscriptions; or
(4) Disable or delete the user's account
There is no backend "unsubscribe another user's subscriptions" feature.
- romagromov
- Senior Member
sozzled wrote: (3) Login to the user's account yourself, and remove their subscriptions;
How?
- romagromov
- Senior Member
xillibit wrote: By going in their user profiles and in the subscriptions and by removing subscripions
How I can login in user profiles? I don't know their passwords )))
in order to unsubscribe users from topics I suggest you to do this:
1. Go to Menus -> Kunena Menu -> Add New Menu Item. For Menu Item Type select Kunena Menu - My Topics and in menu parameters for Select View choose My Subscriptions. Publish this menu Item for registered users only.
2. Go to Joomla User Manger and find your user you want to unsubscribe -> Edit this user -> insert new password twice and Save.
3. Go to Frontend of your forum and Login with credentials of this user
4. Click on My Subscriptions menu item. This will show you the list of all subscribed topics for this user
5. By using bulk actions at bottom of the list you can select all topics and unsubscribe user from them.
Hope this helps.
