Solved "sidebar registered" problem
13 years 10 months ago - 13 years 10 months ago #139004 by yuri1982
I have the same problem....the sidebar i see in not all PAGES
htaccess: Exists | PHP environment: Max execution time: 240 seconds | Max execution memory: 70M | Max file upload: 64M
Joomla default template details : sj_worldnews | author: YouTech Team | version: 1.0 | creationdate: 07/25/1012
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.3 | creationdate: 2012-11-24
Kunena version detailed: Kunena 2.0.3 | 2012-11-24 [ Reconciliation ]
Third-party components: UddeIM 2.9
Third-party SEF components: AceSEF 2.5.5
Plugins: Search - Kunena Search 2.0.3 | Content - Kunena Discuss 2.0.2
Modules: Kunena Latest 2.0.2 | Kunena Stats 2.0.2
Last edit: 13 years 10 months ago by yuri1982.
13 years 10 months ago #139369 by teddysu81
I finally fixed the sidebar problem. Its caused by CB extensions called, CB Forums or Forum Integration. You need to navigate to CB Forums > Config > Models > Kunena 2.0.0 > Sidebar. If you type anything on that boxes, the avatar will be replaced by whatever you typed.
