Solved Post form not showing up
13 years 7 months ago - 13 years 7 months ago #133611 by [email protected]
Thanks- I loaded the page with the default atomic template, and had the same issue, but I did also get a message saying "You do not have permissions to start a new topic!".
I got this when logged in as both the super admin and the general site member.
Last edit: 13 years 7 months ago by [email protected].
13 years 7 months ago #133612 by sozzled
Replied by sozzled on topic Post form not showing up
That explains why you the form does not show up. This is controlled by the Permissions tab in the category where you want to start a new topic. You've probably set the permissions to Nobody (can start a new topic).
13 years 7 months ago #133613 by [email protected]
Thanks- I went into the permissions tab for my only published category, but it only allows me to set access levels. The access levels are fine- the right users can see the right menu items. But where would I set the permissions for the category to allow users to create?
13 years 7 months ago #133614 by sozzled
I am assuming the following things:
(1) You "played" with Joomla ACL groups - big mistake if you do not know what you are doing
(2) You have removed the example section and topic created for you when you installed K 2.0.2 - big mistake if you have not properly tested that you can post a message using the example category
(3) You probably have not read Sections, Categories, sub-Categories (Part 1) - not very wise if you want to apply custom settings to your own categories.
(4) You have published the category.
So I do not know, for sure, what you've done.
Can we see screenshots of any one category exhibiting the problem, please. Further, your updated configuration report on the (properly hosted) website, would also help. Thank you.
13 years 7 months ago - 13 years 7 months ago #133618 by [email protected]
Ok- I've uploaded a live version- www.cctestserver.com/asbc/index.php/kunena .
I'm able to create a new section and category, and set the access levels. I've gone back to simply using the registered user group (As is the default).
The "New Topic" buttons that appear when you click an existing category or topic work fine. The issue is with the "New Topic" link in the main Kunena menu.
I've also applied the Atomic template to discount any custom template issues.
Here is the updated config report:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : amatikulu-ski-boat-club-custom | author: Andrew Paterson | version: | creationdate: 13 Aug 2012
Plugins: None
13 years 7 months ago - 13 years 7 months ago #133644 by sozzled
It all works. I trashed and rebuilt your Kunena menu. Using a standard Kunena menu and it all works.
I also made one small change to the arrangement of your ACL groups but, for the most part, this all looks OK to me.
Last edit: 13 years 7 months ago by sozzled.
The following user(s) said Thank You: [email protected]
Time to create page: 0.279 seconds
