Solved Some posts are only visible in SQL database
14 years 2 months ago #133067 by Maszek
I am running a Kunena Forum on a website with just a little traffic. I recently migrated to 2.0.2. Sometimes the forum is visited by spambots, which is not a very big deal because I remove them when I moderate the posts.
I thought that the front end was showing me all the posts, but when I checked my SQL database recently for explicit language, I found out that some spam-posts are still in the database and not visible in the front end. (Kinda makes one wonder what valid posts are not shown in the front end either.)
Does anyone else experience this problem? How can I make everything posted visible in the front end?
Needless to say that I am looking for a magic button!
14 years 2 months ago #133101 by sozzled
I studied this question for several minutes and I have to admit total defeat in trying to find an answer for it. Without actually knowing anything about these messages that exist in the database (but are "invisible" on the forum), I'm guessing that they're deleted messages. Without spending any time going into phpMyAdmin, you will probably find (in the table kunena_messages) a column called "deleted" that has a boolean value (0 or 1). This is a wild stab-in-the-dark.
However, as I have offered on previous occasions, I am available (at normal consultants' rates) to investigate this if you see it as a problem for you. ;)
14 years 2 months ago #133147 by Maszek
As you read in our other thread , I found a way to remove obsolete entries from the SQL database in MyPHP admin.
Only message text entries are deleted via the front end via moderation, if I remember well (it was late when I finished last night).
Apart from getting rid of the surplus of posts, I deleted 6,000+ (spam) users, 6,000+ user topics, messages etc. I got rid of some 300 kB of useless data. Quite amazing what superfluous data Kunena stores in its database!
Funny: I also found a table of previously installed Kunena versions. Between v1.5.9. and v.2.0.2 I went through 7 versions! I decided to keep that table. It's a piece of my webmaster's history.
