Merged Meta description tag
13 years 10 months ago #138967 by parslej
I read tags should be implemented in Kunena 2.0
Does it really have possibility to add some tags to posts ?
(Coudnt find such option)
13 years 10 months ago #138978 by ultralion
Replied by ultralion on topic Meta description tag
I have too this problem (no topic description in meta tags only GLOBAL site meta tags description is present), how i can fix this??? I did't understand at all how and where i can apply this modify in administrator/components/com_kunena/libraries/view.php
Somebody can help me?
13 years 10 months ago #138983 by TKtemp
as far I'm aware tag feature in kunena id developed but not finished, so disabled.
You cannot use it currently.
13 years 10 months ago #139019 by sozzled
parslej: I am not sure I understand exactly what you mean by the term "TAG". If you could explain better how you understand this term, perhaps I could point you in the right direction where there may be other information on this subject. Thank you.
13 years 10 months ago #139055 by parslej
I'm thinking about metadata tags: en.wikipedia.org/wiki/Tag_%28metadata%29
So ability to mark posts by some keywords, which should help in searching, also find user similar posts
Good example might be stackoverflow.com/
13 years 10 months ago - 13 years 10 months ago #139099 by xillibit
The feature has been disabled in Kunena 2.0 because it's not completly finished
Last edit: 13 years 10 months ago by xillibit.
The following user(s) said Thank You: haraldundandrea
