- Thank you received: 11
Solved Cannot remove messages
- anonymous01
- Premium Member
I have tested under J!1.526, the messages are right deleted in trash manager
Part of messages leave properly, a part - to remove it is impossible. I do not understand dependence. I cannot remove the message of already removed user. Probably, a problem in it? Check up please, the problem is not solved.
- anonymous01
- Premium Member
- anonymous01
- Premium Member
sozzled wrote: You can permanently delete any messages from the database if you know where to look. If you are really anxious to delete these messages, use a tool like phpMyAdmin and find the record(s) in kunena_messages table and a corresponding record in kunena_messages_text table and delete them.
Ok, but what is the reason for collision? This is due to the upgrade? Or problem v. 2.0.2?
I am pleased to hear that my suggestions has solved your problem.Smirnov wrote: Ok
I have no idea what is the reason. There have only been a couple of reports. Sometimes it's more difficult to find the cause than it is to fix the problem so that it doesn't happen again.Smirnov wrote: what is the reason for collision? This is due to the upgrade? Or problem v. 2.0.2?
It's like when you get a hole in the roof of your house. You say "why did I get a hole in the roof of my house?" The hole was caused by nature. It's easier to repair the hole in the roof of the house than it is to change nature. Sometimes these things happen even in the so-called "perfect" world of computer software and, sometimes, it's easier to repair the damage than it is to cure the cause of the problem.
