Question User can not change their Avatar
14 years 3 months ago - 14 years 3 months ago #132022 by stampgo7
Hi there,
I have to problems to submit:
1. Regular user can delete their own posts, although in settings under ''User Can Delete Own Post'' I put never.
2. Noone including administrator can upload or change avatar in the profil menu.
Can you please help me?
My report configuration settings are:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 12M
Joomla default template details : rt_ionosphere | author: RocketTheme, LLC | version: 1.4 | creationdate: July 20, 2012
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Plugins: Content - Kunena Discuss 2.0.1 | JomSocial - My Kunena Forum Menu 2.0.1 | JomSocial - My Kunena Forum Posts 2.0.1 | JomSocial - Kunena Groups 2.0.1
Modules: Kunena Latest 2.0.1 | Kunena Stats 2.0.1 | Kunena Login 2.0.1 | Kunena Search 2.0.1
Last edit: 14 years 3 months ago by stampgo7.
The topic has been locked.
14 years 2 months ago #132051 by sozzled
(1) Your configuration report shows that you do not have these Joomla extensions installed on your website: Community Builder, JomSocial, AlphaUserPoints. Use the Kunena Plugin Manager to disable all integration with those other extensions.
(2) Unless you know exactly what you are doing, disable integration with Gravatar/
(3) Because you are not using JomsSocial, you do not need the following software: JomSocial - My Kunena Forum Menu 2.0.1, JomSocial - My Kunena Forum Posts 2.0.1 and JomSocial - Kunena Groups 2.0.1.
(5) I cannot see where you have published Kunena Latest 2.0.1, Kunena Stats 2.0.1 or Kunena Login 2.0.1. It looks like you have downloaded and installed all the Kunena add-on software, extra things that you do not need.
(6) I cannot figure out how your Kunena menu works. I suggest you simplify it, delete your current menu and try using the default menu instead. After you get your menu to work then try adding your own custom menu items and check to see if your users can upload and change avatars.
(7) The most common reason that people cannot upload or change avatars is because of folder permission settings. Can you edit or change any other profile information?
(8) Chances are you have modified the standard Joomla ACL settings and that is why your users can delete messages.
The following user(s) said Thank You: stampgo7
14 years 2 months ago #132377 by stampgo7
Thanks for your fast reply.
I followed your instructions and the problem with users avatars is now ok but I can not figure out the issue about topics that has been posted by registered users: In the configuration panel, in security tab, under ''User Can Delete Own Post'' I checked the option never, but still a simple registered user with no maderation rights can delete his own post.
Can you please help me on this?
One other thing is that when I enable RE Captcha it appears on the top of the page and not like here after the message.
14 years 2 months ago #132394 by sozzled
As you see, the subject of this topic is "User cannot change their avatar". Other people may be interested in knowing what you needed to look at to fix this problem. This is why we like to keep one question per topic. If you have other questions, please search the forum for answers to those questions or start a new topic.
If you decide to create new topics for your other questions, please remember to include as much information as you can about the problem. Questions that contain as much information that people can give us are generally answered very quickly. Please see the FAQs page which contains a few important tips that may help you when you ask questions.
This topic is now closed.
