Solved Recent Topics and Recent Posts behaviours?
14 years 3 months ago - 14 years 3 months ago #130772 by woonydanny
hi,
still finding my feet with K2.0
I have set up new menu items for Recent Topics and also for Recent Posts.
The Recent Topics does not display in order of which topic was last replied to. Instead it displays by the original topic creation time. How can this be changed to function like K1.7?
On the Recent Posts page it shows every reply, so all replies to a topic are listed and not condensed into one. is this behaving as it is designed?
I would have thought that Recent Topics would be listed by creation date and not change order depending on replies and Recent Posts would list by creation date and order by the last reply but also only list the last reply to a topic not list out all the replies to that topic.
can someone please let me know how to set this up/ explain the designed behaviour.
thanks
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
Last edit: 14 years 3 months ago by woonydanny.
14 years 3 months ago #130792 by sozzled
To be honest, I haven't experimented with the Recent Posts menu type and I don't know how it behaves differently to the Recent Topics menu type (see image below):
Perhaps someone can help us to understand the differences and maybe that will explain what you need to do to resolve your current issue.
14 years 3 months ago #130812 by woonydanny
hmm, i just had a look at kunena.org and the Recent Topics menu item and it is functioning how I want mine to work as well.
Is K.org running K2.01/K2.02?
How is the menu item for Recent Topics setup?
14 years 3 months ago #130827 by sozzled
At this website, the Recent Topics view behaves as everyone would expect it to behave, namely, to display the topics, starting at the top with the topic that was most recently updated with a message posted to it and, going down the page, the topics that were next most recently updated with a new message. That's what we want to achieve in your case, yes?
So, when you wrote,
this is not how the Recent Topics view has ever worked in any version of Kunena. The "recent topics" view lists the topics in the order they were last updated, not the order when the topics were created (i.e. the date of the topic's first posting). Perhaps you're confusing your understanding with something else?
The website here is using an in-development version of K 2.0.2.
I cannot see any menu item settings that affect the ordering of the output. Can you? :dry:
14 years 3 months ago - 14 years 3 months ago #130866 by woonydanny
hi, yes that is how I want mine to work as well. This was how my site worked in K1.7 and now i am running the 2.02DEV for some strange reason the Recent Topics does not order them in order of which topic was replied to last. It orders them by the creation date of the topic itself.
Maybe this is a bug with K2.02DEV?
I have looked through the kunena config settings and also the menu item settings and i cannot see any settings that affect the ordering either....
see image below showing how the topics are not ordered by the replies??
14 years 3 months ago #130882 by sozzled
That's very strange because that's definitely not the way things are happening at this website and this website is using K 2.0.2 DEV dated 2012-07-17 There has to be some other factor that explains the difference between the way things work your website and the way things work here.
Would it be possible to see your configuration report?
