Solved How can I display more than 24 emoticons?
14 years 4 months ago #130027 by ganimede
hi,
I have a problem with emoticons. The new emoticons upload work and if i write in the topic the emoticons code, it's work, but a don't see it to the list (in fact, i can't see all emoticons but only 24).
How can i see all emoticons? or, can I have a button that when pressed it open a pop-up with all emoticons?
Thank's a lot (and sorry for my english!!!!)
(Italian traslation: traduzione italiana:
Ho un problema con le emoticons. L'upload funziona ed anche l'emoticons se scrivo nel topic il suo codice, ma non la vedo nella lista (in realtà non vedo tutte le emoticons ma solo 24!). Come posso vederle tutte? oppure, posso a vere un pulsante che se premuto mi apre un pup-up con tutte le emoticons?
Grazie 1000.
Gani
14 years 3 months ago #130498 by jplamp
See the last page of this thread. www.kunena.org/forum/119-Feature-Request...ble-smileys?start=30
Another user came up with a code that puts a "plus" icon at the end of the list. When you click it, it opens up to show all your emoticons, above the text editor.
I discovered one thing when using it - you have to check the box for "Emoticon Bar" on each new emoticon that you add. Otherwise, it won't show up.
Hope this helps!
Kunena 4.0.11, Joomla 3.5.1, CB 2.0.14, DOCman 2.1.5, uddeIM 3.8
