Solved
ktopmenu > Possibility to remove certain options?
I'd like to remove or disable certain features in the "ktopmenu" for "normal" registered users.
Example: Normal users should not be able to edit their profiles nor to view their own topics, as they will not be able to create new ones. Moderators or administrators on the contrary should be able to use these features.
Has anyone an idea on how I can manage to realize this the best/fastest/easiest way possible?
Thanks a lot in advance for your replies!
Last edit: 14 years 3 months ago by guitarman. Reason: post can be archived/deleted, as the problem could already be solved ;-) thx.
It's a regular Joomla menu, so just set access level above registered, and they will not see the items.
Best regards
Fribse
Dykkerklubben Dannebroge
www.dkdb.dk
We're a volunteer driven diving club in Mosede, Denmark.
Har du brug for en dykkerklub der rummer alle, så kom ned til os.
