The Kunena team has announce the arrival of Kunena 6.4.13 [6.4.13] in stable which is now available for download as a native Joomla extension for J! 5.4.x/6.0.x./6.1.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.0 Hint: This version is primarily intended to facilitate an upgrade if Joomla was first updated to version 6.1 before Kunena was up to dated.
Question
How do I enable the display of icons messaging and private message
No. But instant messaging and other icons can be displayed in this layout?
Do vertical layout displays the same information about you as vertical layout?
You asked, "How do I enable the display of private message icon?". The answer is that you need to install a private messaging system, that is compatible and integrated with Kunena.
I am answering the question you asked in msg #1 as simply as possible.
You'll want to answer the second question?
[strike]Do vertical layout displays the same information about you as vertical layout?[/strike]
[strike]If so, how can enable the display of information on a view of TOP?
Regards![/strike]
*** Moderator's comment ***
One question per topic, please, particularly when the second question is unrelated to the first question. Before you ask whether something displayed in the Blue Eagle template changes its appearance depending on the parameter settings you use, please test the issues for yourself, first, before you post your question on the forum. Thank you.
