Solved Topicicons after upgrade to 2.0.1
13 years 11 months ago #129109 by keithyoung89
I notice that at least 1 topicicon does not display since upgrade from 1.7 to 2.0.1. I see that previously (v1,.7), topicicons were located at:
.../components/com_kunena/template/default/images/icons/[filename]
and now (2.0.1):
.../media/kunena/topicicons/default/user/[filename]
I attach two screen shots to show the example of topic-smile.jpg. I have copied topicicons from the v1.7 folder to v2.0.1 folder so they are present in both versions. However, for this example, you see that in the 1.7 post topic-smile.png is displayed but in the 2.0.1. post default.png is displayed.
Configuration:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : ja_purity_ii | author: JoomlArt.com | version: 1.2.0 | creationdate: August 2011
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Plugins: None
Modules: Kunena Latest 2.0.1
Any advice gratefully received.
13 years 11 months ago #129148 by sozzled
The topic icons used in K 1.6/1.7 were replaced in K 2.0.
The differences between the two versions is illustrated below:
I looked at your website and I see that many topics are now using the new K 2.0 topic icons. From what I see, you seem to have topic icons working but the extent to which any existing topics on your forum use the new icons depends on whether you had modified the K 1.7.2 source code to allow more than the 8 icons that your users could choose from.
If you want to use the older topic icons, you need to move them (as you correctly identified) into the folder ../media/kunena/topicicons/default/user/
13 years 11 months ago #129180 by keithyoung89
Thanks again sozzled. I am still puzzled as to why the 1.7 version uses topic-smile.png but after the upgrade to 2.0.1, although the image is present, it displays default.png. Why does it not display topic-smile.png? I haven't amended any core code (wouldn't dare!)
13 years 11 months ago - 13 years 11 months ago #129189 by sozzled
I think that most of us would agree, topic icons in earlier versions of Kunena we're (a) under-utilised, and (b) when they were used, did not actually convey any real information. The use of topic icons in K 2.0 has been improved - we think so, anyway. However, the specific answer to the question - why do topics that had the "smiley face" topic icons use the "default" topic icon - is several levels above my pay grade. I don't know the answer.
Last edit: 13 years 11 months ago by sozzled.
13 years 11 months ago #129193 by keithyoung89
Well, if you don't know the answer, sozzled, nobody will! :) I'll not worry about it too much.
13 years 11 months ago #129203 by onki
Hi Keith,
I just found a solution regarding the pagination when using JA Putity thanks to the Joomlart forum:
www.joomlart.com/forums/showthread.php?6...tion-in-JA-Purity-II
Just add this at the end of the template.css:
/* KUNENA PAGINATION */ #Kunena .kpagination li { border: 0 none; display: inline-block; font-size: 0.667em; line-height: 1.5em; list-style-type: none; margin: 0; padding: 0; }
Best regards
Onki
