Solved K 2.0.1: Thumbnails not showing in posts, full size images instead
14 years 4 months ago #128565 by rsi
Hi, as the subject says thumbnails are not being displayed in the posts on my forum, the full sized images are displayed instead.
I'm new to using Kunena, this is the first site I'm using it in. I have searched the forums and haven't found any articles with a similar problem or resolution.
I have 'Enable Lightbox for Images' = Yes, Thumbnail Height & Width both = 32 pixels.
I've worked my through all the config items avaialble but can't find anywhere else that may have anything that may effect this.
Please see the attachment for a screen shot of a test post.
14 years 4 months ago #128572 by sozzled
Can you post a picture of what you would like to see instead? Maybe something from this website that shows us the problem that you are having? Did you read How to insert images? - I know that topic relates to K 1.6/1.7 but the same principles apply in K 2.0, too. :)
I hope that helps.
14 years 4 months ago #128844 by rsi
Thanks. Yes this does explain the behaviour I am seeing. Using the <Insert> button inserts the image into the article instead of attaching it.
