Solved URLs Problem. Upgrading kunena1.7.2 to 2.0.1
14 years 4 months ago - 14 years 4 months ago #128419 by skizo
Hello. I just update kunena 1.7.2 to 2.0.1 in my joomla test site, versión 2.5.6, and now the forum doesnt work. I have many problems, one is because of friend urls of joomla. If it is on, the urls forum are as that:
mysite.com/foro/Smart%20Search/Joomla!%20Update.html?view=category&catid=2.
It is wrong. However if i remove in joomla the friends urls, it work well.
Thanks.
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago #128430 by sozzled
It's difficult to give you an exact answer (without knowing more about your website - see FAQs menu item above), but I think you have a problem in the way that you've setup your Kunena menu. As a general guide, you should read Search Engine Optimisation (SEO) in the Wiki.
14 years 4 months ago #128433 by skizo
Hello, this is my test site:
www.zonawiki.com/foros.html
The structure of categories is ok, but to click in them, the urls is missing.
When it is kunene 1.7.2, all ok.
thanks!
14 years 4 months ago #128436 by sozzled
Please use the information I gave you in my last reply. Thank you.
We cannot give you any further advice without knowing more about your website.
14 years 4 months ago #128655 by Matias
Do you have 3rd party SEF component? I'm asking mostly because you need to upgrade that component to a version that supports Kunena 2.0 as our internal urls have changed.
14 years 4 months ago #128657 by skizo
No, I dont use 3rd party SEF component. This site is very simple, only test purpose.
My problem is solved, all ok, more or less.
This was because after upgrading, I tried to use the main menu links had Kunena 1.7.2, because there were, but did not work either. The solution was to go to forun tools click on menu manager and order to create a new menu operating in the main menu. I think this is a bug, the update should remove all entries before, in menu creating, or at least indicate that there is somewhere to delete it manually.
Thanks and regards.
