- Thank you received: 1
Question Omitting Login Option
14 years 4 months ago #126717
by Dhruba RC
Omitting Login Option was created by Dhruba RC
I have read the post under, www.kunena.org/forum/K20-Test-Reports/12...CB-1-8-1-integration , to remove the login option from Kunena forum. But I am sorry I could not figure out how exactly to do it. I am using CB and login integration with CB is working fine with Kunena 2.0. Earlier (in 1.7) in configuration under integration selecting Login and Registration "none" would have done the trick. Now I tried to locate Kunena Login module or any option from plugin manager to be disabled / uninstalled but did not locate any.
Any assistance in this regard will be greatly appreciated.
Thank you,
Thank you,
The topic has been locked.
14 years 4 months ago - 14 years 4 months ago #126730
Replied by sozzled on topic Omitting Login Option
K 2.0.0 is not officially released yet.
The technique in K 2.0.0 is the same as it was in K 1.7.2, to remove the login form from the top of the forum, is to read Disabling Kunena log in , as I advised you to do before.
Last edit: 14 years 4 months ago by sozzled.
14 years 3 months ago #127482
by Dhruba RC
Replied by Dhruba RC on topic Omitting Login Option
Hi Sozzled,
I have waited for a week and am using the stable latest release of Kunena in my local server. But am still perplexed by your answer that the integration options have remained unchanged and I will still be able to disable the kunena log in window at the top of the forum the same way I did in K 1.7. The integration tab is no longer inside kunena configuration and most of it can now be regulated from the plug in manager.
It is a fact that "login & registration" used to be an option which I could disable to hide the kunena log in window; within community builder integration plug in all the previous options of avatar, profiles etc are given even enable community builder log in is set to yes but there is no option to disable "log in & registration". How do I make the kunena login/forgot password/register window disappear?
Community Builder & Kunena is perfectly in sync and there is no problem with that.
I am really sorry that I keep repeating this niggle in the forum but it is important that I disable this feature of kunena.
Many thanks for your time & patience!
14 years 3 months ago #127498
I answered this in more detail yesterday. See
Hide / Disable login
. I hope that helps.
14 years 3 months ago #127560
by Dhruba RC
Hi Sozzled,
I set enable Joomla login to no and it did not work. I have also set enable kunena profile and avatar as set to no which means of course that the users are taken to their community builder profiles. But the log in window still appears at the top.
Thanks!
Thanks!
14 years 3 months ago #127570
by GoremanX
www.friendlyphotozone.com
Replied by GoremanX on topic Omitting Login Option
Hello Dhruba RC,
In the Joomla plugin manager, use the drop-down box to select type "Kunena". Go through all the active Kunena integration plugins and make sure that "Enable XXX Login" is set to "No" in all of them. It works fine on my site. You might be forgetting the "Enable Joomla Login" one.
