Solved Problems with timezone setting
14 years 1 month ago #133989 by alexisdc
Good evening!.
I have a problem with timezone setting, the message is:
Fatal Error: Uncaught exception 'Exception' with message 'DateTime::__construct() [datetime.--construct]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead' in /var/www/vhosts/atex.com.es/httpdocs/administrator/components/com_kunena/libraries/date.php:22 Stack trace: #0 /var/www/vhosts/atex.com.es/httpdocs/administrator/components/com_kunena/libraries/date.php(22): DateTime->__construct('2012-09-26T21:5...') #1 /var/www/vhosts/atex.com.es/httpdocs/administrator/components/com_kunena/libraries/date.php(105): KunenaDate->diff('now', true) #2 /var/www/vhosts/atex.com.es/httpdocs/administrator/components/com_kunena/libraries/date.php(153): KunenaDate->toTimeAgo(1348689570) #3 /var/www/vhosts/atex.com.es/htt in components/com_kunena/libraries/date.php on line 22
I readed that the problem could be from the php.ini file, I sent an email to my hosting asking to change it to: date.timezone='Europe/Madrid' but still without working.
The joomla is 1.5.26 clean installation + userport
Then I´ve installed kunena 1.5.7 and load to the data base from the other kunena.
The result was correct, all the data, messages and registered was ok, but at the moment to upgrade to kunena 2.0.2 the problem appears.
Thank you for your help!.
14 years 1 month ago #134035 by alexisdc
Good morning!
Problem solved!.
Sometimes is necessary to be patient!!!.
Today in the morning the modifications were did the effect and now it´s ok!.
The hosting changed the php.ini date.timezone to the right one and that´s all.
Thank you!.
Alexis
