Solved Issue with timezone settings in my system
14 years 4 months ago - 14 years 3 months ago #129776 by aekunited
500 Internal Server Error
Fatal Error was detected!
Fatal Error: Uncaught exception 'Exception' with message 'DateTime::__construct() [datetime.--construct]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Asia/Krasnoyarsk' for '7.0/no DST' instead' in C:\AppServ\www\s5\administrator\components\com_kunena\libraries\date.php:22 Stack trace: #0 C:\AppServ\www\s5\administrator\components\com_kunena\libraries\date.php(22): DateTime->__construct('2012-07-22T17:3...') #1 C:\AppServ\www\s5\administrator\components\com_kunena\libraries\date.php(105): KunenaDate->diff('now', true) #2 C:\AppServ\www\s5\administrator\components\com_kunena\libraries\date.php(153): KunenaDate->toTimeAgo(1342949766) #3 C:\AppServ\www\s5\administrator\components\com_kunena\models\config.php(201): KunenaDate->toKunena('ago') in components/com_kunena/libraries/date.php on line 22
The error was detected in the Kunena Component.
Last edit: 14 years 3 months ago by xillibit.
14 years 4 months ago - 14 years 4 months ago #129777 by aekunited
Replied by aekunited on topic Help me plz
PHP Version 5.3.15
Apache Web Server Version 2.2.8
MySQL Database Version 5.0.51b
phpMyAdmin Database Manager Version 2.10.3
1.5.26 joomla version
and kunena 2.0-2.0.1
Last edit: 14 years 4 months ago by aekunited.
14 years 4 months ago #129778 by aekunited
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 24M | Max file upload: 200M
Joomla default template details : basics | author: Shape5.com | version: 1.0 | creationdate: February 2010
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Plugins: None
14 years 3 months ago #129804 by xillibit
Replied by xillibit on topic Help me plz
In your first message can-you set a title more descriptive to you problem ?
Edit your php.ini by putting the correct timezone : nl3.php.net/manual/en/timezones.php
The following user(s) said Thank You: aekunited
14 years 3 months ago - 14 years 3 months ago #129817 by aekunited
i'm add
[Date]
; Defines the default timezone used by the date functions
;date.timezone = Asia/Bangkok
but have error again
and include
date_default_timezone_set("Asia/Bangkok");
in date.php
it work again but see in phpinfo() it set to Asia/Krasnoyarsk can to change this
Last edit: 14 years 3 months ago by aekunited.
14 years 3 months ago #129818 by aekunited
hahaha
i'm not remove ; in php.ini
and restart apache again it work
