Question Kunena 2.0.1 error 500 post/edit
14 years 4 months ago - 14 years 4 months ago #128722 by Kneko
I upgraded to version 2.0 and 2.0.1 yesterday
When I edit or posting something new shows me the error 500 but after returning to the forum I see that the post is made despite the error.
This is the message showing the error console
Call stack
# Function Location
1 JSite->dispatch() JROOT/index.php:42
2 JError::raiseError() JROOT/includes/application.php:208
3 JError::raise() JROOT/libraries/joomla/error/error.php:251
Any ideas? thanks
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : rt_diametric | author: RocketTheme, LLC | version: 1.0 | creationdate: April 16, 2012
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Plugins: None
Modules: Kunena Latest 2.0.1 | Kunena Stats 2.0.1 | Kunena Login 2.0.1 | Kunena Search 2.0.1
Last edit: 14 years 4 months ago by Kneko.
14 years 4 months ago #128732 by xillibit
Do you have enabled debug mode in Joomla! and Kunena configuration to see what's happen ?
14 years 4 months ago - 14 years 4 months ago #128736 by Kneko
xillibit wrote: Hello,
Yes, and joomla! shows:
Call stack
# Function Location
i have enable them but Kunena does not show anything.
14 years 4 months ago #128777 by Matias
Have you installed any SEF components? To me it looks like that the redirection doesn't work from some reason -- error doesn't happen inside Kunena but during routing.
14 years 4 months ago - 14 years 4 months ago #128881 by Kneko
Matias wrote: Have you installed any SEF components? To me it looks like that the redirection doesn't work from some reason -- error doesn't happen inside Kunena but during routing.
I didnt install any SEF component.
Yes, it seems redirection doesnt work... Kunena menu issue? I have no idea how to fix it.
Thank you for your help.
Edit: I trashed kunena menú and create a new one with forum tools> menu manager but it doesnt work either.
I disable friendly url option for search engine in joomla and Kunena.
14 years 4 months ago - 14 years 4 months ago #128890 by Matias
After closer look into your configuration report I found something that might be causing the issue:
ID Name Menutype Link Path
110Foromainmenuview=category&layout=listforo
111Foro (2)mainmenuview=category&layout=listforo-2
129ForummainmenuItemid=133kunena-2012-07-02
131Foromainmenuview=category&layout=list&catid=0forum
In main menu you can see 3 extra menu items: Foro, Foro (2) and Foro.
Please remove all of those (remember to empty trash) and publish the fourth menu item called Forum (id 129). You can also rename it to Foro if you want to.
Last edit: 14 years 4 months ago by Matias.
Time to create page: 0.158 seconds
