This category is for discussing issues with the K 2.0 Blue Eagle template.
Question line-height and font-height problem
13 years 9 months ago #138886 by rgrae81
theres a little Problem with the Template if
- The Standard Line-Height in Joomla is not 100% (I'm using 175%)
- the font is "Georgia"
problem with the Line-Height is visible at "announcements"
problem with the font is visible at pagination
When I set the line-height to 100% for announcments then it will be displayed correctly.
For Pagination i had to set the line-height to 1.1em or use px for font and line-height
This is more or less for information. I know that the developement will concentrate on 3.0 but maybe you find the time to work also on the old Template for more compatibility.
Is there a way to report Issues outside the Forum for 2.0 and also for 3.0 when I'll test it?
regards
Roman
13 years 9 months ago #138889 by 9themestore
You can add two following code section in the your css file.
1. Fix for announcments:
#Kunena td.kprofileboxcnt ul li { display: block !important; line-height: 1; }
2. Fix for pagination:
#Kunena ul.kpagination li { display: inline-block; } #Kunena ul.kpagination span { display: block; padding: 3px; }
If don't work. Please post link here, i'll provide you a solution.
Regard
The following user(s) said Thank You: rgrae81
13 years 9 months ago #138892 by rgrae81
thank's for solution.
I already had a solution that worked for me.
I only would give response to the Kunena Team and document it, cause in my opinion this is a problem with default web-fonts that shouldn't exist in a default Style B)
Roman
13 years 9 months ago #138912 by 9themestore
I don't think this bug is of the Kunena forum. Anywhere in the template.css file override the height property or line-height property, so there is a conflict of css.
13 years 9 months ago #139553 by mertch
Hi, I had the same problem. I've put lines you wrote on my TP css and for now page # focus are ok on right down corner but can not see correctly PAGE and page on posts.
page on right down corner
page below post
Thanks.
