- Thank you received: 1
Question [Help] Kunena 2.0.2 VS Chrome & Explorer.
John wrote: This problem is caused by your Joomla template, not by Kunena. If you try a standard Joomla template you will see the forum shows fine.
Already tested with a default template. but nothing.
- Jiminimonka
- Elite Member
- YBAS!
sozzled wrote: Sky_80: See My Joomla site menu makes a mess of Kunena .
Also check your Kunena configuration and make sure you have set the width of the forum correctly.
why not fix that problem first and maybe that will fix this problem, too. Have you tried uninstalling your current Joomla template, and any other modules or plugins that it came with, and then try to use a standard Joomla template instead?Sky_80 wrote: In my forums do not work too bbcode
How absurd!
For years, the use of Template Themza Team.
I've never had any problems.
In the days before I used other templates, with 2 or 3 columns ... always Themza Team. But I had no results
As you suggested I tried the Old template:
[A] rtventurindo 17/11/2010. Now the forum and 'back to normal'!
In the folder of templates [A] rtventurindo there is no file mootools.
Still it works!
In those Themza Team there 's always a folder with all the information on motools. I've never had problems from upgrade from 1.7.2 to 2.0.2 to
Do you have any information on how can I solve the template
Themza Team? They are my favorites.
- Thank you received: 2545
