This category is for discussing issues with the K 2.0 Blue Eagle template.
Question Header text letter-spacing
13 years 5 months ago #136212 by dmcdade2003
I want to change the header text on the forum categories. I believe its kheader, but everything I change has had no effect in the css files.
Does anyone know what to change (which css file) for the default template to remove the bold or change the font.
Thank you!
Don
13 years 5 months ago #136213 by dmcdade2003
I think I found the answer:
docs.kunena.org/index.php/Minified_CSS
I'll try it out.
---Is it nessecary for captcha for every forum post? jeesh.
13 years 5 months ago #136218 by Jiminimonka
The CSS file to change will be in your Joomla template, not Kunena.
Please read the FAQ.
Only one question per topic.
13 years 5 months ago #136219 by sozzled
Replied by sozzled on topic Header text letter-spacing
The CSS attribute you are looking will be called "letter-spacing" and you will find it defined in your Joomla site template CSS; probably defined in conncection with a rule about H2 elements. (Very easily identified with Firebug .)
Time to create page: 0.213 seconds
