Question Edit > Ranks
When I ranks in the name and number change would I this message appear:
What can I do ...
Or hear tis in one of the bugs that will be update?
Greets,
Sneaky.
Here is what you do:
Edit administrator/components/com_kunena/admin.kunena.php: line 1956 (add first line):
$rank_images = array()
while($file = @readdir($dir))
Hope that it helps.
You had no ranks and it didn't work. Fixed in SVN.
Hope that it helps.
its not help
can anyone help!!!
also when changing Rank Title it write Missing Parameter :dry:
You can edit it directly from your database...
That was the solution I've found.
- xlgolffari
Your template, eg.
/components/com_kunena/template/default_red/images/___your_language_]
did not contain icons or ranks or emoticons or graphs folders.
Copy those folders from another folder were their exist.
Pena
