Question Logged into Joomla but not Kunena?
17 years 9 months ago #4846 by Garibaldi
My Kunena install (1.0.7b) has had a strange problem - a user will return to the site (and be logged into Joomla) but they are not logged into Kunena. For example, looking at the top their avatar is not displayed and the text says login. In fact, I just noticed this problem here on Kunena.com! I went to search the forum for this issue, and before I searched I was a guest. After the search, I was mysteriously logged in!
Any ideas on how to fix this "login sync" bug so that users are automatically logged into Kunena if they're already logged in on the rest of Joomla?
Thanks!
17 years 9 months ago #4849 by fxstein
Yes we have seen this. This in not specific to Kunena but seems to be across the board with all components in J1.5.9
We have not been able to confirm the source but we believe that is not Kunena related.
Thx!
fxstein
17 years 9 months ago #4854 by Garibaldi
Great thanks for the super fast reply! I guess we'll wait for J1.5.10 to hopefully resolve this!
17 years 9 months ago #4887 by johnnydement
This sessins error has been around our heads for quite sometime already, it's most visible here in kunena but happens other places also... if you don't come from joomla mainsite, but from a bookmarkk directly to kunena or similar, you appear not logged, until you refresh page or follow any link...
It's an important thing, but we're clueless on where to look...
17 years 9 months ago #4906 by OPEN365
Actually this has been a huge issue in 1.5.8. In 1.5.9 I noticed the problem was somewhat reduced so I think the developers at J! have a handle on it for the next version. I hope!
If you have 1.5.8 upgrade ASAP! Because users will have problems especially if you have cache on. In any case cache off really reduces the problem almost to 0.
17 years 9 months ago #4913 by Garibaldi
I think I have a solution to this problem. On the official Joomla site, I came across this thread and this tracker which provide a patch but also claim that the problem is resolved in 1.5.9. However, there is a catch. What you need to do is go into your Joomla Backend to the Plugins section. Make the "Remember Me" plugin come first in the order so that it is before both the Cache and Legacy plugins. Apparently these plugins are the source of the problem but if you make the "Remember Me" plugin first in priority, its able to override them. I've made this change on my site and so far I haven't noticed the issue anymore.
