Question banner positions?
17 years 9 months ago #4336 by Baze
banner positions? was created by Baze
It seems that the positions for banner (fb_1, fb_2, fb_msg_1...) from FB don't work in Kunena 1.0.8.
While 1.0.7 was active you've mentioned that you will post new instructions for banners after 1.0.8 is public..so.. can we have them now pls :)
tnx
17 years 9 months ago #4360 by johnnydement
Replied by johnnydement on topic Re:banner positions?
Starting with 1.0.8 the following Joomla module positions are supported by Kunena:
kunena_profilebox (Inside the profile box - like the share button on kunena.com)
kunena_announcement (Below the profile box)
kunena_msg_1, kunena_msg_2, ... kunena_msg_n (below the n-th post - limited by number of posts per page)
kunena_bottom (below the forum)
Modules can be published for all these positions. As such you can publish a custom html module, that contains adsense code. On kunena.com we have publish adsesne below the first post (kunena_msg_1) and below the 5th post (kunena_msg_5).
Make sure the module are set to public and published.
17 years 9 months ago #4375 by Baze
Replied by Baze on topic Re:banner positions?
i'm using Joomla 1.0.15, and inside the module positions filed i can enter only 10 characters. Anyone else having this issue??
17 years 9 months ago #4418 by pequeno74
Replied by pequeno74 on topic Re:banner positions?
Many thanks, it is a great notice and works fine.
17 years 9 months ago #4482 by Baze
Guys, in Joomla 1.0 you cant put kunena_msg_1 in the module positions because it only fits 10 characters, so the position is saved as kunena_msg which normally doesn't shows the ads on the proper place. Is there any solution for this?
17 years 9 months ago #4525 by fxstein
Replied by fxstein on topic Re:banner positions?
Have not seen that I will need to check this out on the local test servers.
fxstein
