Question display issue with icetheme template.
17 years 9 months ago - 17 years 9 months ago #4006 by korri78
Using Icetheme template with Kunena 1.0.8
I have a display issue like below,,,
The height of article list is way too big.
Any way to solve this problem?
(It happened when I used Kunena 1.0.7 as well)
p.s.
I'm also waiting for the answer from Icetheme team.
Last edit: 17 years 9 months ago by korri78.
17 years 9 months ago - 17 years 9 months ago #4008 by korri78
And
are the menus supposed to be aligned on 2 rows?
or is it also a bug related to the Icetheme template? :dry:
17 years 9 months ago #4012 by fxstein
Yes the moderator buttons are supposed to be aligned like that going forward. They would take up took much space all in one single line, given that new images have been added.
If you can provide us with a link to your install we can check what might be causing the them conflict.
Hope this helps!
fxstein
17 years 9 months ago #4022 by korri78
Thanks, fxstein!
Here is my backup/testing website:
www.ProsTalk.com
17 years 9 months ago #4030 by fxstein
Unfortunately you test site is wide enough for all signatures to show properly. Can you get me a link to a page that is limited in width so a wide signature would break it?
fxstein
17 years 9 months ago - 17 years 9 months ago #4035 by korri78
Yes, fxstein!
I guess you got me wrong~ :silly:
Please check the attached picture and see the difference of the height between here and mine!
and Look at the avatar... it doesn't fill up the avatar section because it is too wide.
