Question Incorrect Avatar displaying
17 years 9 months ago #2587 by Timi
I have Kunena set up to use Jomsocial avatars, but Kunena as the default profile in the forums. The only problem with this configuration is that when looking at other people's profiles, it'll display my avatar and not theirs. Any solution on this? Thanks in adavnce! :woohoo:
17 years 9 months ago #2597 by Matias
It has already been fixed for 1.0.8. I'd advice you to wait. Or are you in hurry?
17 years 9 months ago - 17 years 9 months ago #2598 by Timi
Replied by Timi on topic Re:Incorrect Avatar displaying
No hurry, thanks for the reply! :silly:
Last edit: 17 years 9 months ago by Timi.
17 years 8 months ago #8056 by jokas
hi, are you shure that has been fixed in 1.0.8?
i use this version and it still shows me the wrong avatars in the profil page.
17 years 8 months ago #8349 by jokas
am i the only one with the problem in 1.0.8?
17 years 8 months ago #8355 by grumblemarc
Maybe some info on your setups might help to find the commonality that is causing your issue. All we know at this point is that you have a problem.
