Question js conflict?
17 years 9 months ago - 17 years 9 months ago #252 by ArMyBoT
js conflict? was created by ArMyBoT
I abandoned FB for kunena with the hope of getting rid of nasty js conflict JQuery/mootools.
I'm using J.1.5.9 in legacy with joolart Teline II template.
This is the error coming up with firebug:
$(document).ready is not a function http://<mysite>/components/com_kunena/template/default_ex/plugin/jtip/kunena.default_ex.js Line 1
Anyone?
Thanks in advance and good work with that fork
P.S.: I'll work on italian translation if needed
Last edit: 17 years 9 months ago by fxstein.
17 years 9 months ago #253 by fxstein
Replied by fxstein on topic Re:js conflict?
Welcome!
I believe we have fixed that problem in the SVN (will be part of the stable build)
Can you replace your version of kunena.deafault_ex.js with this one from the SVN:
joomlacode.org/gf/project/kunena/scmsvn/...fault_ex.js&view=log
It should make your error go away. No other changes required.
Hope this helps!
fxstein
17 years 9 months ago #254 by whouse
Replied by whouse on topic Re:js conflict?
You could replace all the $ with jQuery (it would look like this: jQuery.noConflict(); instead of $.noConflict(); )
Here's a reference: devoracles.com/jquery-error-documentread...-not-a-function-sure
Hope this helps some.
17 years 9 months ago #256 by fxstein
FYI - We did that for all root level $ calls for the upcoming 1.0.8 release
17 years 9 months ago - 17 years 9 months ago #267 by Matias
Replied by Matias on topic Re:js conflict?
Actually there were 3 changes, which needed to be done:
components/com_kunena/lib/kunena.link.class.php: line 272 to: $Output .= 'jQuery(document).ready(function ($) { jQuery("body").bind("click", function(e) { clearTimeout(redirect_timeout); } ); });'; components/com_kunena/lib/kunena.link.class.php: line 285 to: $Output .= 'jQuery(document).ready(function ($) { jQuery("body").bind("click", function(e) { clearTimeout(redirect_timeout); } ); });'; components/com_kunena/template/default_ex/plugin/jtip/kunena.default_ex.js: line 1 to: jQuery(document).ready(function() {
17 years 9 months ago #268 by whouse
I'm glad you guys are up on your stuff. It makes me glad to see the continuation and improvements that are being made here.
