Question Is a link to social bookmarking possible ?
17 years 9 months ago #2058 by Amby
I have seen a link to social bookmarking sites in many forums .
Is it possible with kunena ?
Regards ,
Ambar .
17 years 9 months ago #2060 by grumblemarc
It's probably just an extension. You can find many at extensions.joomla.org (JED).
17 years 9 months ago #2069 by Amby
yes many such extensions are available on joomla.org
But was not sure if it will integrate with Kunena ?
I will look more into this . At present do you know if any such extension is available ?
Regards,
Ambar .
17 years 9 months ago #2078 by johnnydement
It would be possible, you could suggest in uservoice, or maybe some skilled user, wnt to take the challenge ;)
It's not very hard, but we don't have the time currently for it, sorry :(
17 years 9 months ago #2080 by Amby
17 years 9 months ago #2871 by fxstein
Hi If you like something similar to out share button in the header section of the forum on every page, this can be done easily in 1.0.8 through the module position: kunena_profilebox. Publish any module you like and it will show there. In this case it is a jscript for the ADD THIS button.
Hope this helps!
fxstein
