Question Include Module (rokslideshow)
17 years 5 months ago #19355 by bigfoot
Hi folks,
I've been having a bit of bother - the mootools-powered rokslideshow module isn't showing up on pages which are part of a separate component (eg. com_weblinks, com_oziogallery, com_kunena etc etc).
I found the way to sort it - I simply add a couple of lines to the head of the component:
<script type="text/javascript" src="modules/mod_rokslideshow/tmpl/slideshow.js"></script> <script type="text/javascript" src="media/system/js/mootools.js"></script>
This works perfectly for some components (com_weblinks) but for others, I have no idea where to insert those lines.
Could somebody point me to the appropriate place in the Kunena code, please? In other components, it'd be "com_weblinks/category/tmpl/default.html" or something, but I can't find anything similar inside Kunena.
Thanks!
Big
17 years 5 months ago - 17 years 5 months ago #19356 by grumblemarc
Um. Why aren't you adding the module to it's own module position? Also you might want to ask RT why the module does not "show up" where it's supposed to.
Last edit: 17 years 5 months ago by grumblemarc.
17 years 5 months ago #19360 by bigfoot
I am - it just doesn't display on some menu items.
Home:
Kunena:
I would get in touch with the developer, but rocketwerx.com isn't loading at the moment, and you have to pay to access their forums.
I can fix the issue simply by adding a couple of lines of code to each component, to include the mootools and rokslideshow scripts, I just need to figure out where to put them.
Where would be the correct place to put them in the Kunena files? It should be the file which contains all the <div> placeholders for the component, but I can't find this in the Kunena directories.
Cheers,
Big
17 years 5 months ago #19376 by Lintzy
17 years 5 months ago #19420 by bigfoot
Thanks, I still can't find the right place to include a couple of scripts though. Every position I try just crashes.
Does Kunena have a <head> or similar?
17 years 5 months ago #19463 by Matias
This works for every component in J1.5:
$document =& JFactory::getDocument(); $document->addCustomTag('<script type="text/javascript" src="modules/mod_rokslideshow/tmpl/slideshow.js"></script>'); $document->addCustomTag('<script type="text/javascript" src="media/system/js/mootools.js"></script>');
