Question How to fit the forum into a template
17 years 2 months ago #1512
by dagit
How to fit the forum into a template was created by dagit
Hi
Ive just installed the forum - all looks great! However, i have a template (downloaded) and the forum is squished into a single column - i can choose to open in a new browser without the toolbar, but then it is unformatted and does not follow the look/feel of the template.
Can anyone let me know how i can incorporate into the template?
Jas
Jas
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
17 years 2 months ago #1534
by grumblemarc
Replied by grumblemarc on topic Re:How to fit the forum into a template
This is accomplished solely in Joomla. You have to make sure you publish/unpublish mosdles that you want to show up on the forum page.
- david.murphy
17 years 2 months ago #1549
by david.murphy
Replied by david.murphy on topic Re:How to fit the forum into a template
Hi
Ive installed Forum into my Joomla site but the layouts look terrible... how do i make it look like this forum? is there sample data i could use to initially set it up?
Dave
Dave
- johnnydement
- Elite Member
- Thank you received: 5
17 years 2 months ago #1598
by johnnydement
Replied by johnnydement on topic Re:How to fit the forum into a template
What you mean? can you post a link?=
If you mean you want to create some categories/forums, yes, you can use sample data form kunena admin
If you mean you want it to get full width of template, you will have to go and edit the modules, to appear only in the sections you want to.
17 years 2 months ago #1748
by dagit
Replied by dagit on topic Re:How to fit the forum into a template
Is there a way to tell Kunena to use a different default template to the one that joomla is using?
I have a problem with the forum not being able to fit into my template correctly and i would rather it was seperate.
- BLaCKie_MoRGaN
- Junior Member
17 years 2 months ago #1764
by BLaCKie_MoRGaN
Replied by BLaCKie_MoRGaN on topic Re:How to fit the forum into a template
Kunena uses its own template, unless the "Use joomla theme" is selected.
To See the forum like this one you have to edit all of your modules and select all the menus except the one for the forum.
Time to create page: 0.215 seconds
