Question Latest Forum Posts Module?
17 years 6 months ago #13661 by PokerFace
I am using Joomla 1.0.15. I am trying to display the latest forum posts on the front page of moderngambler.com and as you can see I am trying out a number of different modules on there. First, I tried out the latest Fireboard module to do this (after not finding any Kunena module), but that didn't work so I had to try out these other modules. I have no problems displaying the feeds, but all the links open in a new window. Is there any way to force one of these modules to open up the forum links in the same window? Is there a working Kunena module for the latest posts that I missed? Where are the Kunena modules at? I could not find any at all..
:huh:
17 years 6 months ago #13662 by grumblemarc
No modules has been officially been developed by the Kunena team. Any that you may find are third party and should be supported by it's developer. Your best bet is to contact the dev in question.
17 years 6 months ago #13665 by PokerFace
I read on here that Fireboard modules do not work with Kunena. So if Fireboard modules do not work and there are no Kunena modules - then I cannot use any modules with Kunena?!
Would I be able to just use the last version of Fireboard so I can use modules?
17 years 6 months ago #13670 by grumblemarc
You misread. I said there are no official Kunena modules. They are all third party. There is one that is being offered and supported by a user from this community on this forum.
Also there is no latest version of FireBoard. FB is no longer being developed.
17 years 6 months ago #13683 by PokerFace
Could you point me in the right direction? I couldn't find it.
17 years 6 months ago #13684 by korri78
There is a User Contribution section.
Go to User Contribution > Modules and find what you're looking for! :laugh:
www.kunena.com/forum?func=showcat&catid=112
