Question Does the ebay widget work for Australia?
17 years 7 months ago #11046 by woonydanny
I cannot seem to get the ebay widget to work for Ebay Australia ( www.ebay.com.au )
The code should be en-AU but when i try that the widget does not work.
Can you please outline which country ebay sites are integrated into Kunena.
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
17 years 7 months ago #11050 by grumblemarc
Could you please start posting in the correct forum? The support forum is the place for questions like these. Not the About Kunena forum.
17 years 7 months ago #11059 by woonydanny
Well to be fair, the Forum Categories on this site are quite vague. They should be more defined, i have thought this from day one when the categories were created.
And I did think about which category before I posted as I like you run a forum and like to keep things organised. My question I thought was about kunena's ebay widget and not directly asking for support.
But in hindsight and in closer inspection of the categories, yes Support would have been a better place to post. But i still do think the categories need more definition, as i just looked in the About Kunena forum category and most of those should be in Support as well.
17 years 7 months ago #11061 by grumblemarc
I'm sorry. It sounds like a support question to me. "I can't get XXXX working. Any thoughts, fixes or solutions?" is a support question.
17 years 7 months ago #11084 by fxstein
The widget should work everywhere around the world where there is eBay. Can you confirm that you get it to work for other language/site codes?
Thx!
fxstein
17 years 7 months ago - 17 years 7 months ago #11148 by woonydanny
I can confirm that it works for en-GB (UK ebay site).
I looked up and saw that the Australian ebay code was en-AU and have tried that, also i tried en_AU, en-au, en-aud and en_aud but neither have worked.
Any other ideas?
Can you get it to work for en-AU or is it just me?
Last edit: 17 years 7 months ago by woonydanny.
