This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Question Kunena discuss plugin does not work when article is in multiple categories
11 years 1 month ago #169394 by ngjtt
I run the kunena discuss plugin on a website that has articles that are placed in more than 1 category. The plugin does not work on these articles. If anybody is interested I found the following fix for this problem:
On line 205 of kunenadiscus.php just after $isStaticContent(!$articleCategory);
cast the $articleCategory variable to an integer
$articleCategory=(int)$articleCategory
This will make the kunena discuss plugin work as if the article with multiple categories is only in the first of its categories
11 years 1 month ago #169442 by ruud
this is new to me: an article in multiple categories... How do you do that? In article manager you can only select one category for an article, or am I missing something?
sharing = caring
