This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Solved Kunena does not work on my mobile device with Shape5 Vertex template
12 years 2 months ago #158757 by Polese
Hi, i have installed kunena 3.0.6 on joomla 3.3.3, but it doesnt work on mobile device, some browsers and linux OS. Doesnt' work the button "reply" to a post. someone know if its a but or its a my mistake? thanks
12 years 2 months ago #158763 by xillibit
Can-you please put here your Kunena report configuration settings like explained here : www.kunena.org/docs/*_Commonly-asked_%28...uration_report.29.3F
You said that it doesn't work on mobile device and some browsers but what's happen exactly ?
12 years 2 months ago #158765 by Polese
Hi, and thanks for quick answer
some user tell me that they can replay or make a topic with some devices, android, ios or linux operating sistem. it happens too with some browser like firefox or chrome, when they click "submit" nothing happens
here my configuration. thanks
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 25M
Joomla default template details : shape5_vertex | author: Shape5.com | version: 3.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: Content - Kunena Discuss 3.0.1
Modules: Kunena Login 3.0.1
12 years 2 months ago #158778 by xillibit
Do-you have looked with firebug console if you see something when you hist submit button ?
12 years 2 months ago #158782 by Polese
It seems nothing happens, i attach a screenshot video where i try to . could be a joomla template problem? thanks
12 years 2 months ago #158783 by xillibit
You can try with default Joomla! default template, else you can give me a test account like that i can do a test, put the data into a
