This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Merged Kunena with AceSEF
13 years 3 weeks ago #150035 by lisamariecratty
I tried to do the update to 3.0.3 and it hung. I was finally able to get it to work by downloading the 3.0.3 zip file and installing it through the extension manager. I can now get into the backend Kunena panel and it appears to be fine, but when I try to load the forum on my website I now get a 500 Internal Server error.
Here is my config report:
Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : kallyas | author: Marius Hogas | version: 1.2 | creationdate: Unknown
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: Jomsocial 2.8.3
Third-party SEF components: AceSEF 2.5.10.6
Plugins: JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
13 years 3 weeks ago - 13 years 3 weeks ago #150041 by xillibit
Replied by xillibit on topic Kunena with AceSEF
Can-you please enable debug mode in kunena and joomla configuration panel to see a more detailled error message ?
In the same time, i advise you to upgrade your joomla version to 2.5.14 and use blue eagle template in version 3.0
Last edit: 13 years 3 weeks ago by xillibit.
13 years 2 weeks ago - 13 years 2 weeks ago #150045 by sozzled
Replied by sozzled on topic Kunena with AceSEF
There are a few of your settings that may be causing problems here:
1) AceSEF 2.5.10.6 is incompatible with K 3.0 - (see Interoperability with other Joomla extensions ) - and has been incompatible with Kunena since K 2.0. Talk to the developers of AceSEF for their advice or disable (or uninstall) AceSEF
2) As xillibit wrote the Blue Eagle template designed for K 1.7.2 is not recommended for K 3.0.3. Use the new Blue Eagle template instead.
3) See To what extent does K 3.0 support Jomsocial
4) Change the settings for the forum integration plugins as shown in red font below:
Kunena - JomSocial Enabled: access=0 login=1 activity=1 avatar=1 profile=1 private=1 activity_points_limit=0 activity_stream_limit=0
Kunena - UddeIM Disabled
5) Simplify your Joomla menu. Try using the standard Kunena menu as discussed in Kunena Menu issues in the Wiki, first, and then see if this helps.
And, lastly, as xillibit wrote, enable debug mode to find out more about the details of the " HTTP 500 Internal Server Error " that you are getting.
I visited your forum - it was hard to find and the page loaded very slowly - but I could not work out how to reproduce a HTTP 500 Internal Server Error error. Perhaps you could tell us what you did to get this error?
And, yes, J! 2.5.11 was buggy and that version is not recommended by Joomla. Update to J! 2.5.14 at the very least.
Last edit: 13 years 2 weeks ago by sozzled.
13 years 2 weeks ago #150076 by lisamariecratty
Replied by lisamariecratty on topic Kunena with AceSEF
Thank you both so much for the help. Ok, I'm getting somewhere with this, but not quite there yet...
I upgraded to 2.5.14 and I changed to the 3.0 template. That didn't make any difference, but when I turned on the debugger I did get more info from the error. It was pointing to a line in com_AceSEF as was suggested. I disabled AceSEF and now I no longer get the 500 error but my forum now starts with many "Strict Standards" errors and goes to the kunena/index page.
Sozzled, I removed the main menu to my forum, that's why it's hard to find! Here's the link: www.mama-janes.com/forum
Thank you!!
13 years 2 weeks ago #150077 by lisamariecratty
Here's a new config file:
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
13 years 2 weeks ago #150078 by lisamariecratty
I just fixed it!! Realized that I still had my debugger turned on. Is there any issue if I was getting a bunch of Strict Standards: Only variables should be assigned by reference in.... type references?
Time to create page: 0.161 seconds
