Question How will Kunena handle Joomla 1.6 (ACL)?
- LittleJohn
- Kunena Contributor
I saw this old article, and became aware of (at least) one fancy new feature; The ACL:
www.jfoobar.org/blog/44-first-look-at-joomla-16-acl.html
It looks to me like Kunena could gain some popularity with eventhooks along with the 'new' ACL (and some (easier/actual?) template system)?
Just wondering .. This might have been discussed earlier, so dev's, no need for comprehensive articles in this matter.
Best regards
This topic has been discussed at this website (here is just one example: Private Forum Access Control and Groups ). So, you can see, the idea has been in the pipeline for a long time!
My understanding is that Kunena 1.6 will be Joomla 1.6-"ready", that is, K 1.6 will be able to use the new ACL features that J! 1.6 will deliver. As you probably know, J! 1.6 has been in the melting pot for nearly 12 months. J! 1.6 Alpha 2 has only just been released, so it's anyone's guess when a stable version will be made available. It's my guess (and it's only a guess) that K 1.6 will come out around the same time.
AS I said, I'm sure the developers will have a much more succinct and better explanation than what I've just written. Cheers
- LittleJohn
I will await more info if a dev. should happen to come by.
(Btw, the templates seems to be separated out of the core logic. Wonderfull!! (Bug #19448; Move code out of template)) :woohoo:
Hello,My understanding is that Kunena [strike]1.6[/strike] 2.0 will be Joomla 1.6-"ready", that is, [strike]K 1.6[/strike] K2.0 will be able to use the new ACL features that J! 1.6 will deliver. As you probably know, J! 1.6 has been in the melting pot for nearly 12 months. J! 1.6 Alpha 2 has only just been released, so it's anyone's guess when a stable version will be made available. It's my guess (and it's only a guess) that K 1.6 will come out around the same time.
K1.6.0 is just k1.5.9 with some news features and some bug fixes.
It's K2.0 will be manage J1.6! ACL and becasue it use MVC it will totally compliant with J1.5!/J.16!.
For the management of ACL in K2.0, nothing is decided yet.
Do you have an idea of a release date?
Cheers!
For K2.0 nothing is decided, so i advise you to read time to time the twitter : twitter.com/kunena
