Solved Kunena 7.1 Beta 2 Released for Joomla! 5.4.x and 6.x
2 months 1 week ago - 1 month 3 weeks ago #235194 by xillibit
Introduction:
The Kunena team is thrilled to announce the second public...
Introduction:
The Kunena team is thrilled to announce the second public beta release of Kunena 7.1, a native Joomla extension for Joomla! 5.4 and Joomla 6.x. This is a development release and should be only be used for testing; this version is not recommended for live websites at this stage. Kunena 7.0 works on Joomla! 6.0 natively without the needs of compat plugin.
The purpose of this release is to encourage testing by downloading, installing and identifying any problems or shortcomings that people may discover. K 7.1.0 B1 is in testing phase and we are aware that people will discover defects. We encourage you to use the forum to report defects, as soon as they are discovered, so that the development team can work through the problems before the release of K 7.1 as a stable product. Reporting defects does not mean that the problems can or will be fixed. The Kunena team is looking forward to hearing your feedback on how well we have achieved our design goals.
Kunena 7.1 has been designed to work on Joomla! 5.4 and 6.0, the requirements are the followings :
  • Php 8.3.0
  • MariaDb 10.4 or MySQL 8.0.13
  • Bootstrap 5.x
The work done in Kunena 7.1 is mostly to update the code base:
  • Remove deprecated code which are planned to be removed in Joomla! 7.0 (replace triggerEvent)
  • Add a way to store the notifications to be send later with the Kunena task plugin
  • Some improvements on the code to optimise a bit the speed
  • Refactor the queries to use Joomla! database query way
  • Allow with a plugin (will be availaible later in subcription page) to add new social in user profile (still on work in progress)
  • Some improvements on SCeditor : add undo plugin and allow to handle some others parameters on inserting an image (thanks to joomod)
Download:
Download K7.1.0 Beta2 here: https://github.com/Kunena/Kunena-Forum/releases/tag/7.1-Beta2
Donations
Any donations are needed for future support.
Last edit: 1 month 3 weeks ago by xillibit.
The following user(s) said Thank You: ssnobben, Leen, 9themestore
2 months 1 week ago #235195 by xillibit
New mail queue in backend :
2 months 6 days ago - 2 months 6 days ago #235197 by Gindi
When updating from Kunena 7.0.8 to Kunena 7.1 beta 2, I see two database errors:
The database schema version (6.0.0-RC1-DEV) does not match the manifest version (7.1.0-ALPHA1-DEV).
The table “‘jom6_kunena_notifications_mailsqueue(’” does not exist. (From file: “7.1.0-ALPHA1-DEV.sql”.)
34 database changes were checked.
5 database changes had no impact on the structure of the database tables and were therefore skipped.
Last edit: 2 months 6 days ago by Gindi.
The following user(s) said Thank You: xillibit, ssnobben
2 months 6 days ago #235198 by xillibit
Thanks to have tested it
I will look later today to investigate in this issue
