Kunena 7.0.8 Released
Question Kunena 7.0.3 stable released for Joomla! 5.4 and 6.0
The Kunena team is thrilled to announce the third maintenance...
Introduction:
The Kunena team is thrilled to announce the third maintenance release of Kunena 7.0, a native Joomla extension for Joomla! 5.4 and Joomla 6.x. Kunena 7.0 works on Joomla! 6.0 natvely without the needs of compat plugin.
For people which wants help for translations, Kunena 7.0 files can be translated on crowdin : crowdin kunena
Kunena 7.0 has been designed to work on Joomla! 5.4 and 6.0, the minimal requirements are the followings :- Php 8.2.0
- MariaDb 10.4 or MySQL 8.0.13
- Bootstrap 5.x
The work done in Kunena 7.0 is mostly to update the code base:
- Refactor all the code of plugin integration to be in Joomla! 6.0 by working with events and to drop the parts which was planned to be removed in this Joomla! version (thanks to ruud)
- New: scheduled task purge trashbin (thanks to ruud)
- Changes on the installer script to be able to work on Joomla! 6.0
- Make user type on whoisonline widget as links to open the userlist filtered
- Remove most of the deprecated code
- Refactor captcha handling conform with Joomla! 5.x and 6.0
New features:
The Kunena system plugin check on registration and on login if the user is in stopforumspam database and prevent them to make these actions
The Kunena configuraion has been converted to be the same that others configurations page in the Joomla! way
Download:
Download K7.0.3 stable here: https://github.com/Kunena/Kunena-Forum/releases/tag/7.0.3
Donations
Any donations are needed for future support.
"Joomla! 6.0.3 is not supported. Minimum required version is Joomla! 6.0.4, but it is highly recommended to use Joomla! 5.4.4 or later."
So, not sure if 6.0.3 is really not supported, or if the message is inaccurate. ie: 5.4.4 or later
- Thank you received: 2537
While this message is correct, it is also confusing.Error message on 6.0.3 Joomla
Kunena 7.0.3 can be installed on both Joomla 5.4.4 and higher as well as Joomla 6.0.4 and higher, but not on Joomla 6.0.3.
Maybe this message should be adjusted.
Joomla 6.0.4 and 5.4.4 are Security releases; you should update to these versions if you are still using the older versions 5.3 or 6.0.3.
www.joomla.org/announcements/release-new...-bugfix-release.html
I have made a change in developpment version of Kunena 7.0.4 and the message displayed is improved
