Kunena 6.4.13 Released
Question Kunena 7.0 Beta 1 Released for Joomla! 5.4 and 6.0
10 months 2 days ago #234017 by xillibit
Introduction:
The Kunena team is thrilled to announce the first public...
Introduction:
The Kunena team is thrilled to announce the first public beta release of Kunena 7.0, a native Joomla extension for Joomla! 5.4 and Joomla 6.x. This is a development release and should be only be used for testing; this version is not recommended for live websites at this stage. Kunena 7.0 works on Joomla! 6.0 natvely without the needs of compat plugin.
The purpose of this release is to encourage testing by downloading, installing and identifying any problems or shortcomings that people may discover. K 7.0.0 B1 is in testing phase and we are aware that people will discover defects. We encourage you to use the forum to report defects, as soon as they are discovered, so that the development team can work through the problems before the release of K 7.0 as a stable product. Reporting defects does not mean that the problems can or will be fixed. The Kunena team is looking forward to hearing your feedback on how well we have achieved our design goals.
Kunena 7.0 has been designed to work on Joomla! 5.4 and 6.0, the requirements are the followings :
  • Php 8.1.0
  • MariaDb 10.4 or MySQL 8.0.13
  • Bootstrap 5.x
The work done in Kunena 7.0 is mostly to update the code base:
  • Refactor all the code of plugin integration to be in Joomla! 6.0 by working with events and to drop the parts which was planned to be removed in this Joomla! version (thanks to ruud)
  • Changes on the installer script to be able to work on Joomla! 6.0
  • Make user type on whoisonline widget as links to open the userlist filtered
  • Remove most of the deprecated code
  • Refactor captcha handling conform with Joomla! 5.x and 6.0
New features:
The Kunena system plugin check on registration and on login if the user is in stopforumspam database and prevent them to make these actions
The Kunena configuraion has been converted to be the same that others configurations page in the Joomla! way
Download:
Download K7.0.0 Beta1 here: https://github.com/Kunena/Kunena-Forum/releases/tag/7.0-Beta1
Donations
Any donations are needed for future support.
The following user(s) said Thank You: Leen, 9themestore
10 months 2 days ago #234018 by rich
The beta displays the wrong version; it shows K7.0.0.
The following user(s) said Thank You: xillibit, Leen, 9themestore
10 months 1 day ago #234019 by xillibit
I have updated the package on github release
10 months 1 day ago #234020 by ruud
And completely refactored configuration into Joomla Core Config.
Mentioning it here is this (might) have impact on extension developers / 3rd party developers.
sharing = caring
Time to create page: 0.212 seconds
