Kunena 7.0.8 Released
Question Kunena 6.3.10 maintenance Release for Joomla! 4.4/5.0/5.1/5.2
1 year 5 months ago #232981 by xillibit
Introduction:
The Kunena team is thrilled to announce the maintenance release...
Introduction:
The Kunena team is thrilled to announce the maintenance release of Kunena 6.3.10, a native Joomla extension for Joomla! 4.4, 5.0, 5.1 and 5.2.
We've implemented native support for Joomla 5. This means you don't have to enable the new compatibility plugin "Behaviour - Backward Compatibility " on Joomla! 5.0 for it to work with Kunena.
Kunena 6.3 has been designed to work on Joomla! 4.4 and later, the requirements are the followings :
  • Php 7.4.1 to Php 8.3.x
  • MySQL 5.7.23 to MySQL 8.3.0
  • Bootstrap 5.1
The work done in Kunena 6.3 is the following:
  • Refactor the backend views to be compatible with Joomla! 5.0 (thanks to ruud)
  • Some bugfixes and refactor of code
  • Replace Twitter by X in all places where it was used and add bluesky social network
  • Replace some deprecated usage of methods Joomla! from in the code
  • Implementation of handle of mentions in a message when using CKeditor
  • Get list of users for autocomplete in search form
Download:
Download K6.3.10 stable here: https://github.com/Kunena/Kunena-Forum/releases/tag/6.3.10
This means that the Kunena 6.2 series is approching the end of life and will be discountinued, with the future release of K6.3 in stable there won't be new versions of K6.2 after that.
Donations
Any donations are needed for future support.
The following user(s) said Thank You: ssnobben, Leen, Pinkeltje
6 months 5 days ago #234573 by xillibit
For users still on Kunena 6.3.10 and Joomla! 4.4.x, Joomla! updater won't suggest anymore to update to Kunena 6.4.9 because to update to this Kunena version you need Joomla! 5.0. And updating Joomla! force you to update Kunena to 6.4.9.
So the update process is the follow :
  1. Make a backup
  2. Update manually to Joomla! 5.2.x
  3. Install Kunena 6.4.9 by Joomla! extensions because Joomla! updater won't show Kunena updates
  4. Make a backup
  5. Joomla! updater now, suggest to you to update to Joomla! 5.4.x, you can do the update
Time to create page: 0.464 seconds
