Kunena 7.0.8 Released
Question Kunena 6.4 RC2 Released for Joomla! 5.0/5.1/5.22
1 year 7 months ago #232672 by xillibit
Introduction:
The Kunena team is thrilled to announce the second public...
Introduction:
The Kunena team is thrilled to announce the second public release candidate of Kunena 6.4, a native Joomla extension for Joomla! 5.0, 5.1 and 5.2. This is a development release and should be only be used for testing; this version is not recommended for live websites at this stage.
The purpose of this release is to encourage testing by downloading, installing and identifying any problems or shortcomings that people may discover. K 6.4.0 RC2 is stable and we are aware that people will discover defects. We encourage you to use the forum to report defects, as soon as they are discovered, so that the development team can work through the problems before the release of K 6.4 as a stable product. Reporting defects does not mean that the problems can or will be fixed. The Kunena team is looking forward to hearing your feedback on how well we have achieved our design goals.
Kunena 6.4 has been designed to work on Joomla! 5.0 and later, the requirements are the followings :
  • Php 8.1.0 to Php 8.4.x
  • MySQL 8.0.13 to MySQL 9.1.0
  • Bootstrap 5.1
The work done in Kunena 6.4 is the following:
  • Removing CMSObject extends to some Kunena classes to comply with removed things planned for Joomla! 6.0 (thanks to svanschu)
  • Allow to be used on php 8.4 if you are on Joomla! 5.2.x, it will give some deprecated errors messages
  • Replace some deprecated usage of methods Joomla! of getError(), getDBO() and Toolbar::getInstance()
  • Allow avif and webp to be added in attachment
Download:
Download K6.4.0 RC2 here: https://github.com/Kunena/Kunena-Forum/releases/tag/6.4-rc2
This means that the Kunena 6.3 series is approching the end of life and will be discountinued, with the future release of K6.4 in stable there won't be new versions of K6.3 after that.
Donations
Any donations are needed for future support.
1 year 7 months ago - 1 year 7 months ago #232673 by Gindi
Ich habe die Version 6.4.0-RC2 local zum testen installiert. Im Forum stelle ich immer viele Bilder ein. Das ist mit dieser Version aber nicht möglich.
Nach dem einstellen und speichern von editierten B ilder sehe ich nur noch:
[img][/img]
[img][/img]
[img][/img]
wenn ich aber einen neuen Beitrag erstelle und speichere kommt die Meldung:Die angeforderte Seite konnte nicht gefunden werden. successDie Links oder Bilder wurden aus der Nachricht entfernt, da die Erlaubnis dazu fehlt.Während der Anfrage ist ein Fehler aufgetreten.Die Seite kann nicht angezeigt werden, weil:
  • ein veraltetes Lesezeichen aufgerufen wurde.
  • eine falsche Adresse aufgerufen wurde.
  • über eine Suchmaschine ein veralteter Index dieser Website aufgerufen wurde.
  • keine Zugriffsrechte für diese Seite vorhanden sind.
Zur Startseite wechseln Bei Problemen ist der Administrator dieser Website zuständig.
0 Call to undefined method Kunena\Forum\Libraries\Config\KunenaConfig::get()
und ganz oben steht:
Gruß Gindi
Last edit: 1 year 7 months ago by Gindi. Reason: Ergänzungen
1 year 7 months ago #232674 by Gindi
Nachtrag zu 0 Call to undefined method Kunena\Forum\Libraries\Config\KunenaConfig::get()
Bei mir lautet der Pfad: /libraries/kunena/src/Config/KunenaConfig.php
Gindi
1 year 7 months ago - 1 year 7 months ago #232675 by xillibit
Please write here in english, thanks to have reported this issue
Ffrom the error message it seems linked to the feature which remove the links into the message, i need to test with it
Last edit: 1 year 7 months ago by xillibit.
1 year 7 months ago - 1 year 7 months ago #232677 by Gindi
The error description in English.
I have version 6.4.0-RC2 installed locally for testing. I always post a lot of pictures in the forum. However, this is not possible with this version.After posting and saving edited pictures, I only see:
img][/img]
[img][/img]
[img][/img]
but when I create and save a new post, I get the message:The requested page could not be found.
success The links or images have been removed from the message because permission to use them has not been granted.
An error occurred during the request.
The page cannot be displayed because:
  • an outdated bookmark was accessed.
  • an incorrect address was called up.
  • an outdated index of this website was called up via a search engine.
  • no access rights for this page are available.
Go to the homepage.
If you experience any problems, please contact the website administrator.
and at the top it says:The links or images were removed from the message because permission to use them was not granted.
Addendum to 0 Call to undefined method Kunena\Forum\Libraries\Config\KunenaConfig::get()
For me, the path is: /libraries/kunena/src/Config/KunenaConfig.php
Gindi
1 year 7 months ago - 1 year 7 months ago #232683 by Gindi
Joomla 5.2.3 and Kunena 6.3.8
When I install Kunena 6.4.0-RC2 2025-01-08 on my test server and then open the Kunena Dashboard, I see the following messages above the Kunena version check:
Database updated to version 6.4.0-DEV_2024-09-11
Database updated to version 6.4.0-BETA1-DEV
Database updated to version 6.4.0-BETA3-DEV
Database updated to version 6.4.0-BETA3-DEV_2024-11-01
Database updated to version 6.4.0-BETA3-DEV_2024-11-02
Database updated to version 6.4.0-RC1-DEV_2024-12-20
The version 6.4.0-RC2 2025-01-08 is not included, but is displayed in the middle of the dashboard header.
Is it normal to see five updates?
Gindi
Time to create page: 0.235 seconds
