Question Kunena 6.3.4 maintenance Release for Joomla! 4.4/5.0/5.1
1 year 9 months ago #231926 by xillibit
Introduction:
The Kunena team is thrilled to announce the maintenance release...
Introduction:
The Kunena team is thrilled to announce the maintenance release of Kunena 6.3.4, a native Joomla extension for Joomla! 4.4, 5.0 and 5.1.
We've implemented native support for Joomla 5. This means you don't have to enable the new compatibility plugin "Behaviour - Backward Compatibility " on Joomla! 5.0 for it to work with Kunena.
Kunena 6.3 has been designed to work on Joomla! 4.4 and later, the requirements are the followings :
  • Php 7.4.1 to Php 8.3.x
  • MySQL 5.7.23 to MySQL 8.3.0
  • Bootstrap 5.1
The work done in Kunena 6.3 is the following:
  • Refactor the backend views to be compatible with Joomla! 5.0 (thanks to ruud)
  • Some bugfixes and refactor of code
  • Replace Twitter by X in all places where it was used and add bluesky social network
  • Replace some deprecated usage of methods Joomla! from in the code
  • Implementation of handle of mentions in a message when using CKeditor
  • Get list of users for autocomplete in search form
Download:
Download K6.3.4 stable here: https://github.com/Kunena/Kunena-Forum/releases/tag/6.3.4
This means that the Kunena 6.2 series is approching the end of life and will be discountinued, with the future release of K6.3 in stable there won't be new versions of K6.2 after that.
Donations
Any donations are needed for future support.
The following user(s) said Thank You: Leen, Pinkeltje
1 year 8 months ago #231977 by Petley
Hello
With the bugs reported on attachments , is this OK to install this update?
Terry
1 year 8 months ago #231980 by rich
If you mean this bug, github.com/Kunena/Kunena-Forum/issues/9697 it is fixed.
This bug is still open github.com/Kunena/Kunena-Forum/issues/9722
Time to create page: 0.442 seconds
