Kunena 7.0.8 Released
Loved Kunena 5.0.2 and Kunena 4.0.12 released
9 years 11 months ago #180089 by TDman
After upgrading to 4.0.12, I was notified in Joomla Control Panel that the upgrade to 5.0 was available. After backing up my site I decided to try upgrading to 5.0. I was hoping that I could easily resolve any template issues that popped up. I never could get the forum to display properly even with the default Protostar template. I had to restore the backup I had made, including the database, to get back to normal.
I'm not complaining. We were given ample warning that this could happen. The problems I had could probably have been worked out if I had the time.
I'm just posting my experience for those who might decide to go down this road once they have the 4.0.12 upgrade installed. Backup, backup, backup if you decide to upgrade to K 5.0
Kunena 4.0.11
Joomla! 3.5.1
Template: Car Deluxe - By Web Design Builders
9 years 11 months ago #180091 by 810
If your joomla template doesn't have the modern classes/style. then you can enable the "Load Bootstrap" option on the crypsis settings.
If you have to many issues you can go back to 4.0.12 by just installing the k4.0.12 package. There is no need to restore the database.
9 years 11 months ago #180096 by TDman
Thanks for the tips. If I had known about the load bootstrap option I might could have made it work. When I get some free time I will try again. I might try an new Joomla template at the same time. How can I be sure a new Joomla template would be compatible with K 5.0?
Kunena 4.0.11
Joomla! 3.5.1
9 years 11 months ago #180097 by 810
most new templates are compatible, just look for bootstrap template, also gantry is working,
The following user(s) said Thank You: TDman
9 years 10 months ago #180280 by lorenzo70
Hello
With Kunena 5.0.2 (PHP 5.6.xx - joomla 3.6.2) i can't load the Attachment
9 years 10 months ago #180283 by 810
please create a new topic for it.
Time to create page: 0.247 seconds
