- Thank you received: 5
Important Use Move, Merge and Split instead of one Moderate Topic button
- baijianpeng
- Premium Member
15 years 4 months ago #74321
by baijianpeng
www.joomlagate.com/
Chinese Joomla Users' Portal
I noticed that Kunena 1.6 use Moderate Topic button to replace the button of "Move Topic", "Merge Topic" and "Split Topic". I think this is a bad idea.
Most users had seen these Move, Merge and Split buttons on other popular forum programs, such as phpBB or SMF or VBB. In face, these buttons became a set style that everyone is accustomed to.
I also found that the single "Moderate Topic" button is too difficult to understand and use.
So, Hope you will discard this Moderate Topic button, and just use Move, Merge and Split buttons as most forum programs do.
Thanks.
Thanks.
www.joomlagate.com/
15 years 4 months ago #74340
by xillibit
Replied by xillibit on topic Re: Use Move, Merge and Split instead of one Moderate Topic button
If this is asked by a lot of people we could set back the buttons Move Topic", "Merge Topic" and "Split Topic" with a configuration setting...
- baijianpeng
- Premium Member
15 years 4 months ago #74450
by baijianpeng
www.joomlagate.com/
Replied by baijianpeng on topic Re: Use Move, Merge and Split instead of one Moderate Topic button
I think you also should consider of the user habit, most people are customed to the usual button set which uses Move, Merge and Split seperately.
Thanks.
Thanks.
www.joomlagate.com/
15 years 4 months ago #74494
Replied by sozzled on topic Re: Use Move, Merge and Split instead of one Moderate Topic button
This topic was originally posted in the K 1.6 Support category. There is nothing broken or defective in K 1.6 as far as this issue is concerned. I have moved this topic to the General Talk about Kunena category to allow other users to contribute their views on the topic.
Let us see what other people have to say.
15 years 4 months ago #74499
by kiwi3685
Replied by kiwi3685 on topic Re: Use Move, Merge and Split instead of one Moderate Topic button
As an admin and moderator I already have 7 buttons to choose from (reply, delete, sticky, lock,favourite, new topic, moderate topic). I think that's quite enough, thank you. No need for any more. Its not as if Move, merge and split are used many times every day. I like the current format.
I would also add that there is no logic to the statement "consider the habit of the user" unless there is good evidence those habits are the best one to have. Change is often a GOOD thing
Kunena is leading the way here (as in many things). I'm sure the other forum products will follow and move their options to a single "Moderate" option eventually.
14 years 10 months ago #99579
by juncloudy
Replied by juncloudy on topic Re: Use Move, Merge and Split instead of one Moderate Topic button
<?php echo $this->message_merge; ?>
seems not working in k 1.6? how can i have the merge functionality back?
Time to create page: 0.223 seconds
