Important Use Move, Merge and Split instead of one Moderate Topic button
15 years 4 months ago #74321 by baijianpeng
I noticed that Kunena 1.6 use Moderate Topic button to replace the button of "Move Topic", "Merge Topic" and "Split Topic". I think this is a bad idea.
Most users had seen these Move, Merge and Split buttons on other popular forum programs, such as phpBB or SMF or VBB. In face, these buttons became a set style that everyone is accustomed to.
I also found that the single "Moderate Topic" button is too difficult to understand and use.
So, Hope you will discard this Moderate Topic button, and just use Move, Merge and Split buttons as most forum programs do.
Thanks.
www.joomlagate.com/
Chinese Joomla Users' Portal
15 years 4 months ago #74340 by xillibit
If this is asked by a lot of people we could set back the buttons Move Topic", "Merge Topic" and "Split Topic" with a configuration setting...
15 years 4 months ago #74450 by baijianpeng
I think you also should consider of the user habit, most people are customed to the usual button set which uses Move, Merge and Split seperately.
Thanks.
www.joomlagate.com/
15 years 4 months ago #74494 by sozzled
This topic was originally posted in the K 1.6 Support category. There is nothing broken or defective in K 1.6 as far as this issue is concerned. I have moved this topic to the General Talk about Kunena category to allow other users to contribute their views on the topic.
Let us see what other people have to say.
15 years 4 months ago #74499 by kiwi3685
As an admin and moderator I already have 7 buttons to choose from (reply, delete, sticky, lock,favourite, new topic, moderate topic). I think that's quite enough, thank you. No need for any more. Its not as if Move, merge and split are used many times every day. I like the current format.
I would also add that there is no logic to the statement "consider the habit of the user" unless there is good evidence those habits are the best one to have. Change is often a GOOD thing :-))
Kunena is leading the way here (as in many things). I'm sure the other forum products will follow and move their options to a single "Moderate" option eventually.
14 years 10 months ago #99579 by juncloudy
<?php echo $this->message_merge; ?>
seems not working in k 1.6? how can i have the merge functionality back?
Time to create page: 0.314 seconds
