Question Color scheme and Jom Social
- Charl Laas
- Junior Member
A lot of sites will be running Jom Social and Kunena together - like yours and mine for instance.
Would it be possible to develop a default Kunena template that uses the default JS color schemes.
Using one of the hacks on the forum I have started to modify one of my forum to do so. You can view it at www.charllaas.com/forum .
The hack unfortunately isn't extensive enough to completely overhaul the template. I'm using YooTheme template Symphony and the template allows for customization by having a file called custom.css. This file doesn't get upgraded when the template is upgraded, allowing for hacks like this to remain unchanged.
This is what the hack looks like currently in my custom.css file:
/* Change the link colors
*#Kunena a:link,
*#Kunena a:visited,
*#Kunena a:active {
*color:#4E6221 !important;
/* Change the header background colors */
#Kunena .kblock div.kheader {
background:none repeat scroll 0 0 #789539;
/* Change the header text colors */
#Kunena .kblock div.kheader h2 a:link,
#Kunena .kblock div.kheader h2 a:visited,
#Kunena .kblock div.kheader h2 a:active {
color: #fff !important;
/* Change the tab colors */
div#ktab ul.menu li a {
background-color: #666666 !important;
/* Change the active tab & rollover colors */
div#ktab li#current a {
background-color: #789539 !important;
div#ktab ul.menu li a:hover {
/* Change the border color under the top nav */
#Kunena #ktop {
border-color: #789539;
/* Change the pagination color */
#Kunena .kpagination .active {
border:1px solid #789539;
#Kunena .kpagination a {
#Kunena .kpagination a:hover {
border:1px solid #0B55C4 ;
background: #0B55C4;
/* Change the post link color */
#Kunena div.kmsg-header h2 a {
/* Change the toggler color */
#Kunena #ktop span.ktoggler {
background-color:#0B55C4;
/* Change the button rollover color */
#Kunena .kbutton:hover, #Kunena .kbutton:focus {
background-color: #0B55C4;
border-color: #0B55C4;
I disabled the link colors, for when this is changed via the hack you also loose the legend colors and the hover effect over the links. Also the blue icon images remain which then becomes an eye sore all blue on it's own. This is as far as I got balancing the colors with my limited coding knowledge of CSS.
I hope anybody can give me some ideas on how to refine the template even more! :woohoo:
Experience is that marvelous thing that enables you to recognize a mistake when you make it again.
Franklin P. Jones
- Charl Laas
- Junior Member
Templates and colors are a fickle thing with most people as you know. At the moment non of those templates are exactly what I'm looking for, style and color wise. Also most of them come at a cost and when you buy them they still carry a 'developed by xxx' sign which I don't want.
The one I am interested in, is the Gainsboro Kunena Template but it is only compatible with Kunena 1.5.12!!
It was because I couldn't find what i was looking for that I started playing with this hack, which is awesome by the way. Thanks Severdia.
If someone wants to take what i have done so far and develop it into a commercial template I'll be happy to pay for it, as long as their is no 'develop by xxx' sign at the bottom.
Ps. In retrospect I should have posted this in the Template and design forum, sorry
Franklin P. Jones
