- Thank you received: 1
Question Hilfe bei Migration Kunena 5 auf 6 --- a little help Update K5 to K6?
Ich werde es probieren wenn ich das Joomla Update geschafft habe
- Thank you received: 186
But in the end my conclusion is that K5 and K6 Tables in database are unchanged? This will be a helpful information in this situation!
I'm working now several Weekends end evenings with nearly no visible progress (only coming more and more to the scratch) and I'm getting to the point to discontinue my page after 25 Years.
Privat Sites are going to vanish because of this technical reasons and also law reasons
I know there is nobody to blame for, because Joomla and Kunena is also a Community driven thing by people who do this in their free time as well and I'm thankful for that and all the support over the years.
Can'reproduce. When I search for Kunena in Extensions - Manage and select all and then uninstall, everything from Kunena is gone.red marked (by Joomla upgrade) Kunena package.
About database: It might be that structure of your Kunena tables is slightly changed, but that doesn't affect your data.
- Thank you received: 2545
Aktualisiere deine Joomla-Installation und wenn dieser Vorgang erfolgreich war, importiere die Kunena-Tabellen. Anschließend installiere Kunena 6.x (es startet die Migration) und danach mache diese Schritte fertig: docs.kunena.org/en/basics/upgrade/upgrade-k6-x
Zuletzt importiere aus der Sicherung /media/kunena die Inhalte von den Ordnern attachments, avatars ung gegebenfalls, falls du eigene Smilies hast, auch von emoticons. Das ist alles.
Ich habe Migrationen gefühlte hunderte Male getestet und es hat immer funktioniert.
If you have completely removed Kunena via tools, it is also no problem, provided that you have an extra backup of the Kunena tables and the /media/kunena folder as described here: docs.kunena.org/en/basics/upgrade/upgrade-k6-x
Update your Joomla installation and if this process was successful, import the Kunena tables. Then install Kunena 6.x (it starts the migration) and then continue with these steps: docs.kunena.org/en/basics/upgrade/upgrade-k6-x
Finally import the contents of the folders attachments, avatars and, if you have your own smilies, emoticons from the backup /media/kunena. That's all.
I have tested migrations what feels like hundreds of times and it has always worked.
