Question Displaying forum topics on the mobile problem
9 years 8 months ago #184143 by wkschab
Hi:
I have a small problem with displaying topic posts on mobile. kmsg-header - containing topic name is covered by profile info with avatar. It is a minor thing but I would like to fix it. I hope that maybe someone experienced similar problem and fixed it. Thank you in advance for you help,
Wojtek
Please see the attachment
9 years 8 months ago - 9 years 8 months ago #184200 by WolfgangOWL
You are not the only one who has this problem. There is no fix that I know of.
See here
Last edit: 9 years 8 months ago by WolfgangOWL.
9 years 8 months ago #184240 by WolfgangOWL
I am currently working on a solution for the problem. It will not take too long until I'm finished.
On mobiles it will look like this:
The solution will only work for Crypsis and not for Blue Eagle 5.
9 years 8 months ago #184250 by WolfgangOWL
I'm finished and it is working on my website without problems.
9 years 8 months ago - 9 years 8 months ago #184324 by WolfgangOWL
Will this be fixed in future versions of Kunena? The ::after selector is supposed to insert something after the content. You use it to insert the headline before the content. This is really weird and is the reason why it's not working properly with long message-header text. I have my solution for the time being but it would be better if I would't have to fix it myself after every Kunena update.
9 years 8 months ago #184325 by rich
@Wolfgang
Is your solution for Crypsis generally? Why you not write it as suggestion on Github? We have already some proposals accepted from you and inserted in Kunena.
Time to create page: 0.145 seconds
